FridayGt
All sorts of epic man, thanks! I'll see what I can dig up on that other connector. Although, out of curiosity, would the fact that my under dash light worked before have any bearing? I also don't have the 4-speed hump. Man, I wish I had the fender tag. I'm going to have to roll the dice and see if the build sheet is still in the seat.
Found the black with white stripe wire. That car has a 4-speed reverse light harness in it. I would tape up the exposed connector and forget about it. It was originally connected to the dash mounted reverse light, should have a single wire coming into the engine department through a rubber grommet from the light. Appears it was an original 4-speed car. The other double black wire female I can't find in the diagrams, would need to know what cavity of the bulkhead connector it originates to identify the circuit.
