360 J heads vs 318
Sonny
6:46 AM
Florida
I have a 1978 360 engine I just put in my Belvedere. It has 318 heads on it. Is there an advantage to putting a set of 1974 360 J heads on it? There is a guy on craigslist selling a pair fresh from the machine shop for 200 bucks.
yes, the 360 heads have larger valves and ports than the 318, but the chamber is larger too, so it would drop the compression ratio a bit. Why does the 360 engine have 318 heads?
No idea. It was a low miles crate engine bought this summer. Runs great but looking at getting those heads. What’s the impact of reduced compression? Does it cancel out the larger valve upgrade?
Good question. Maybe look for Rumblefish on this site (knows a TON about small blocks). If you have a "340/360 intake port size" intake manifold, then 1/3 of your incoming air is hitting a "cylinder heads port wall" which is horrible for flow. My gut instinct is that any compression advantage of smaller combustion chamber (318) heads is nothing compared to the flow loss at both the intake runners & the smaller valves vs. the 340/360 heads. Also, if you're worried about lowering your compression, you could always use some "stock style" (very thin) head gaskets....just my 2-cents. I'd buy those heads if the guy can provide paperwork on the rebuild.
I agree. buy the 360 heads, the lower compression will help with the lower octane fuel anyway and they already had the hardened seats.
I'm wondering which 318 heads those are (possibly the later 308 swirl ports?). If so. they may be on there for compression/velocity reasons. What's the specs on your motor? I know you said it was a '78 but you also mentioned it was a crate motor as well.
l don’t have any info on it. That’s what l was told. And that it came out of a ‘78 Karry-van. Here’s a few pics. Notice the tiny exhaust ports. lntake openings are small too.
Someone/somewhere on a forum said the intake manifold mis-match is no big deal because the intake charge is sucked in (like a vacuum cleaner) and not pushed in from the outside (like a blower). I don't know if that theory is more "correct" than what PurpleBeeper stated in post #4 or not. Just a thought.
I dont think there is a difference in 318 360 exhaust manifolds. From what i have read the swirl heads are preferd
If you could read the head casting numbers it would tell which heads they are. Should be on the head under the valve cover/rocker gear. As mentioned, if they are the 308 heads, they are supposed to be pretty good.
Yes those are either #302 or the #308 "swirl port" casting heads. You can tell by the plugged air ports below the exhaust ports. They have a closed heart shaped chamber and good flowing ports for a factory head. I wouldn't change them.
Ps, the 74 J heads are small valve open chamber.
Hey Sonny. I’m on vacation right now in Palm Bay over by Melbourne this week. I don’t have any books on hand to decode any numbers you may gleem from the cylinder head.
I hate to say this but I truly don’t mean any harm by what I’m about to say, most of the info above is wrong.
This site rocks for big blocks co knowledge which I sorely lack on. These guys got that down packed tight.
As a note to everyone, I’m going to quote everybody and correct some of the information as a correction and nothing else, so don’t get pissed off at me when I quote and correct.
I mean no harm in any way shape or form.
This is 50% correct or backwards. If the 360 heads go into a 318. It would be more accurate to view it as returning the engine to its proper ratio, which would be lower. How low? Depends on where the piston sits and the head gasket used.
Lots of variables and unknown parts.
Generally speaking, in a low performance package, 1 pt. in ratio is 3% and probably less for your stockish set up, if it is stockish.
So, for example, IF your engine is making 300 HP, your down 9 hp. Larger valves question.
1.88 vs. 1.78 is an answer I can not calculate due to a lack of information. But I’d call it a worry move. I have felt a noticeable difference in moving from a 1.88 to a 2.02. It wasn’t a huge difference at all but one that was noticed.
Member IQ52 did do a test on Flow vs. compression and the clear winner was flow!
Super agree with this and thanks for the Kudos buddy.
While the 1/3 mention maybe off, the idea still holds true. I never measured the port sizes or did a measurement of actual amount of port wall interference. But it is something to avoid if possible.
That was the quick, 5 in the morning answer. Since we really don't know any specifics about the engine, Normally the 318 head will have a smaller sized combustion chamber than the 360 head, which would result in a higher compression ratio than the 360 head with all other variables being the same.
318 swirl port heads are to have the “302” Designation. Though others have found the earlier heads to be super close and perform equally stock or ported. The 302 has a slight advantage and thus is the reason MP used that head for there performance ported 318 head. (Also IMO because it was the current head being casted.)
The ported 302 made 55 hp more than the 360 head on there little bit rod 318.But that’s a 318 & we are talking 360 here, so..... moving along.....
This has merit. Small amounts. The way it all works is a long explanation. It would take a while to explain it all in detail with science and pictures. David Vizard does an excellent job.
After the cylinder fires and the exhaust valve opens up the exhaust gas starts going out of the cylinder. There is a pressure wave that travels down the exhaust pipe and then back upstream to the head and then Back out. As this wave leaves it creates a negitive pressure area that helps create a wave that the air and fuel ride on like a surfer into the cylinder.
That was a simple explanation that is really dumbed down but provides a picture that everyone can see.
This is responsible for filling the cylinder more than anything and if tuned... OH BOY! Whatch out!
Keep in mind that the higher pressure from outside is pushing its way through the carb. This accounts for a little bit like the surfer paddling for the wave.
