velrob
trying to figure out why my tranny has no end play.
took it apart again. should I be able to push the input shaft in and out easily and have it move slightly? I have a dial indicator. I'm using the thinnest fiber ring I have. also should I be able to spin the output shaft easily with the pump on?
I noticed the bushing that sits on the input shaft is tight.
all seals and bushings are new along with frictions and plates.
lastly should I be soaking the frictions in tranny oil for 30 minutes thanks
