MCODECUDA
Please Stop calling them freeze plugs!
They are casting core plugs and have nothing to do with coolant freezing.
Thank you for correcting me. You are correct of course! my bad. I sincerely apologize. I have gone back and edited my post. Some things bug a person and I understand that. For me, it's when people refer to the Passon 5 speed transmission (made by Passon Performance) as a "Passion 5 speed transmission". See New TransmissionsPlease Stop calling them freeze plugs!
My Red Challenger was a /6 car originally, I was collecting parts for a V8 swap from the day I bought it... But I drove it with the / for a couple years... The last winter with the / I went skiing & left the car parked at home in the driveway... When I got home I jumped in & went for a drive... About 4-5 miles later the thing was barely running, when I popped the hood all the freeze plugs yes freeze plugs.. Were laying on the oil pan rail... I banged them back into their holes with a rock & filled the radiator with water.... Drove it for another four months before I began my V8 swap....Must be from the South, as they're definitely referred to "frost" plugs up here, as they blow out when the block gets frosty!![]()
99 percent of the world call then freeze plugs or frost plugs. Kind of like a Pussy which is a vagina and nothing to do with cats.Please Stop calling them freeze plugs!
Possibilities;why were you ever running straight water?
I had that same problem years ago. I put a heating pad (for your back) on each side of the block. Next morning all was thawed out. Sounds crazy but it worked!
Not casting core plugs ?Just saying...
If you want to drain it completely, yes.I used the heating pad for the top rad hose.
And just got one block drain plug out and water came out. Stupid question, do both side block plugs need to come or is one side enough?
