Results 1 to 8 of 8
Thread: Blue coil?
  1. #1
    Senior Member
    Join Date
    Nov 2011
    PA
    Posts
    352
    Country
    United States
    Thanks
    8
    Blue coil?
    I've noticed that most max wedges have a blue ignition coil - what's the source for these?
    Thanks
  2. #2
    Senior Member
    Join Date
    Nov 2011
    PA
    Posts
    352
    Country
    United States
    Thanks
    8
    Nobody?
  3. #3
    b stung daredevil's Avatar
    Join Date
    Jul 2008
    houston tx.
    Posts
    2,716
    Country
    United States
    Thanks
    111
    Are you talking about the blue streak coils from Standard motor products?
    lean mean rubber burnin machine
  4. #4
    FBBO Gold Member RustyRatRod's Avatar
    Join Date
    Jun 2011
    In a house.
    Posts
    6,734
    Country
    United States
    Thanks
    810
    Those were the only blue ones I ever knew of. The Blue Streak was Standard Ignition's HP line of ignition products. As such, they were molded out of much thicker and blue plastic. Ignition coils were hotter and thicker and blue. Just like caps and rotors. The rotors had extra thick bodies and extra thick electrodes. The caps all were very thick and featured "walls" on the inside around each plug wire electrode to help keep arcing to a minimum.
    That wasn't all of the Max Wedge ignition system by a long shot, either. Real Max Wedges (not Street Wedges) had a sho nuff optional transistorized (read breakerless) distributor. I think it was made by Prestolite. Folks think the advent of electronig ignition was in the early 70s. Not true. The Max Wedges had that beat by a long shot. A lot of people will argue the fact. But the guy I work for knew of a local older gentleman who owned one of these cars that had the optional ignition system I'm talking about. Maybe one of the guys on here will know what I'm talking about. All you ever see in print was that they all had dual point ignition systems, but that's not entirely true. I've heard and read about it in other places too.
  5. #5
    Senior Member
    Join Date
    Nov 2011
    PA
    Posts
    352
    Country
    United States
    Thanks
    8
    Maybe it's a coincidence, but just about every max wedge car that I have seen lately has a sort of light petty blue ignition coil. They look like a regular coil and are mounted where you would expect them, I figured it was for a reason, and it looks good so I figured I would copy it. Probably just an off the shelf auto zone replacement. lol
  6. #6
    Join Date
    Jun 2011
    In a house.
    Posts
    6,734
    Country
    United States
    Thanks
    810
    You may be exactly right. I wasn't saying that the Blue Streak coils came on there...just that they were the only blue ignition parts I knew of. They don't make it anymore that I'm aware of, at least not in this country. Too bad, too cause it was good stuff.
  7. #7
    Senior Member
    Join Date
    Nov 2011
    PA
    Posts
    352
    Country
    United States
    Thanks
    8
    I'm thinking it's either a cheap-o parts store coil, a vintage blue streak, or people are painting theirs as a nod to the old blue streaks.
  8. #8
    Senior Member
    Join Date
    Sep 2009
    Coeur d Alene
    Posts
    396
    Thanks
    4
    Evidently there WERE some. The "Transignitor"
    At the bottom of the page is a screenshot out of a Google Book:
    http://books.google.com/books?id=-cs...gnitor&f=false
    "How to Hot Rod Small-block Mopar Engines
    By Larry Shepard"
    Standard Blue Streak
    Sacriledge:
    Attached Images Attached Images
Similar Threads
  1. 68 Coronet 500 convertible Blue $9,500
    By kidsixpack in forum B Body Mopars For Sale
    Last Post: 10-01-2008, 01:10 PM
  2. Holley Blue electric pump and reg.
    By 69 Runner in forum OLD --- B Body Mopar Parts For Sale
    Last Post: 09-19-2008, 09:19 PM
  3. Blue check marks
    By '68-Charger-Guy in forum Website Suggestions, Questions and Comments
    Last Post: 09-05-2008, 12:07 AM
  4. i need a 71-72 blue ringed ralley light switch knob
    By my66-67-68-69-72bbodies in forum Mopar Parts and Cars Wanted
    Last Post: 08-01-2008, 12:20 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
