After reading a couple of the other threads, I have a couple of questions on a disc brake conversion for my 68 Charger:
1. My car will be mostly street and some track. Do the single piston calipers used in the conversion kits and noted from other threads to use from bone yards off of 70’s Mopars, stop as good or better then the original four piston calipers from 68?
2. I understand the one piece 70’s rotor will do better with heat than the original 2 piece. Correct?
3. My car has four way manual drums. I picked the power brake portioning valve, master, and booster off a 68 charger parts car. Does it matter what proportion valve I use (power or manual brake)? According to my parts book it looks like the same part if I’m reading it correctly.
4. I received a set of single piston caliper disc brake set-up along with my car. Only part number I can find on the assemblies is on the caliper: XH (or maybe KH) 09832501. Anyway to tell if this is the correct set-up for my car? I can provide a pic if that will help.
5. Some of the conversion kits say not to use 14” wheels. Why? If I use the 70’s mopar set up will 14” wheels be ok?
Any help is greatly appreciated.
Thanks!
Paul :icon_salut:
Thanks!
Paul :icon_salut:
