how to drop an engine and tranny?
Engine, Trans & Driveline
Inactive Reminders By Icora Web Design
07-29-2010, 07:37 PM
#1
Junior Member
so is there any good or easy way to remove those? should i pull it all together or unbolt them and pull them one at a time?
im striping down my 78 cordoba and we can asume that everything in the engine bay is gone.
07-30-2010, 12:08 AM
#2
Senior Member
Drop from the bottom or pull out through the top? I have pulled many engines and trannys out from the top without problems. Just double check that everything is disconnected!
__________________
Looking for 1966 HEMI parts
I had MoPars before it was cool to have MoPars!!
07-30-2010, 12:32 AM
#3
Senior Member
Asuming you don't have a bridge?
Think it's easier (read: lighter) to remove the engine and tranny separately if it concerns an automatic tranny.
07-30-2010, 01:37 PM
#4
Junior Member
what is a bridge? if it is posible i would like to drop it from the botom whit the front removed then back the car up?
doing so leaving the engine on the ground and then putting it on a pallet.
07-30-2010, 02:18 PM
#5
Senior Member
A bridge is something to drive over to get to the other side.
07-30-2010, 02:54 PM
#6
Senior Member
Ive put them in that way, keep in mind you have to pull the upper control arms loose trans mount exhaust speedo cable shifter or linkage all the connections under the hood and be able to support the engine and trans and lift the car. I used my cherry picker, the front of my rotisserie
07-30-2010, 03:32 PM
#7
Senior Member
Location: overland park kansas / own a salvage yard in odessa missouri
your very dangerous DAD
__________________
07-30-2010, 03:34 PM
#8
Senior Member
Quote:
Na, there was no weight, no interior, glass. if its a complete car I would use a lift or pull it out the top. Hey when did I become a senior member, do I get discounts? and how did they find out I'm a little older
07-30-2010, 10:50 PM
#9
Senior Member
Quote:
I ratted you out , no early bird specials here , even for national magazine stars
__________________
07-31-2010, 11:28 AM
#10
Junior Member
since im bringing down the car to nothing i could do this.
so the engine and trany can come straigth down.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
