B Body Mopar B Body Mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY   FOR SALE   REGISTER   FBBO STAFF
 NEW POSTS  TODAYS POSTS  SEARCH  CALENDAR  SITE HELP  A BODY MOPAR FORUM  E BODY MOPAR FORUM
Go Back   B Body Mopar Forums > Classic Mopar Tech > 1966 - 1970 Mopars
Belvedere rear ends
1966 - 1970 Mopars
Reply
Thread Tools Display Modes
Inactive Reminders By Icora Web Design
Old 07-29-2010, 09:48 PM   #1
oliver
Junior Member
Default Belvedere rear ends
Put my new 66 belvy with a slant and 3 speed manual on the lift and noticed that i came with a 7.25" rear axle I thought the smallest rear end available on them were the 8.25"... i also noticed that in this chart
the 7.25 was never available.... i was going to just regear when i swap in my small block but now it seems like i have to do a rear end swap. If i end up finding a 8 3/4 i did notice the width between the spring perches are different, how did they mount the springs closer together? Should i keep the stock width and reweld, or change the mounting on the car? Thanks!
oliver is offline   Reply With Quote
Old 07-30-2010, 12:45 AM   #2
Meep-Meep
Senior Member
Meep-Meep's Flag is: United States
Meep-Meep's Avatar
Default
I don't know if that chart is completely accurate. I could be mistaken, but I had a 68 Belvedere slant 6 3 spd with a 7.25 rear end.
One way to change the spring width is to use offset shackles and modified front hanger. Also the chart says the 8.25" B body and the 8.75" 62-70 B body has a different spring CL width. I don't recall having that issue.
__________________
Looking for 1966 HEMI parts
I had MoPars before it was cool to have MoPars!!
Meep-Meep is offline   Reply With Quote
Old 07-30-2010, 05:45 AM   #3
RGAZ
Senior Member
RGAZ's Avatar
Default
My 69 came with a 8.25 and I swapped a 8.75 with no problems. Width matched perfect.
Randy
__________________
1969 Roadrunner 6-pack clone
1973 Triumph Spitfire 1500 (converted to 3.8L)
1993 Ford F-250 LB - For hauling toys
The day I got her...
RGAZ is online now   Reply With Quote
Old 07-30-2010, 08:34 AM   #4
70WM21 W1 V6B
Senior Member
70WM21 W1 V6B's Flag is: United States
70WM21 W1 V6B's Avatar
Default
I too saw a lot of 7.25's in B Bodies and they do NOT take any kind of abuse.
As for the 8-3/4 difference I think when you get the 8-3/4 you also got a heavier duty leaf spring (wider also) which if swapped as an assy springs and axle it would bolt right in with the difference being leaf spring width which when split between the 2 would be 1/2" per side centerline pivot. I do not think the factory tooled up different uni bodies for 7.25 rear axles, only the hanger brackets, springs and shackles and shock plates and axle.
If your gonna swap out the rear axle go with the 8-3/4 for sure, there should still be plenty of housings floating around.
70WM21 W1 V6B is offline   Reply With Quote
Old 07-30-2010, 11:16 AM   #5
oliver
Junior Member
Default
What do you think would be required to swap in a 8 3/4 into the car? The front mount and shackle mounts are in different locations than 8 3/4 cars. How do they differ?
Old 07-30-2010, 08:34 PM   #6
Manifold
Manifold's Avatar
Default
Yeah, that chart isn't complete.
Take a few measurements, the important one being the spring perch width. For your car, it should be 44". If there's nothing odd going on with your car, then it should be just a matter of pulling the 7.25 and installing the appropriate 8.75 rear. I'd say stick with a 64-67 B-body rear (earlier than that had the 2 piece axles IIRC), but you would likely be OK with a 68-70 B-body rear - my notes say the 68-70s were slightly wider (like 5/8" overall WMS to WMS). Both of those have the spring perches set at 44" apart.
Be sure to get an accurate measure on any rear you buy! I picked up an E-body 8.75 for my 68 B-body (the E-body rear is 1.5" wider than a '68 B-body rear) which supposedly had the perches relocated for a B-body. My quick measurement wasn't good enough - turns out the perches were set 1/2" narrower than a A-body rear. So, off they came and I welded on new perches at the right width which also allowed me to set the pinion angle just right for my car. Worked out in the end... but meant more work than I had anticipated.
Manifold is offline   Reply With Quote
Old 08-01-2010, 09:37 AM   #7
rrunner
Senior Member
rrunner's Avatar
Default
I don't think, I know it's not. 65-67 8 3/4's are't the same as 68-70, they aren't as wide. That chart shows 68-70 spec's. I also thought the 8 1/4 came along in 69.
rrunner is offline   Reply With Quote
Old 08-01-2010, 06:23 PM   #8
Manifold
Manifold's Avatar
Default
Quote:
It did. I just pulled a 69/70 8 1/4 out of my 68. Ran the casting number to see what it was. It isn't listed on that chart.
Old 08-24-2010, 06:11 PM   #9
dcatcha
Junior Member
dcatcha's Flag is: United States
Default
Here is the complete 1966 Shop Manual for the car, and it is FREE!!
http://www.mymopar.com/index.php?pid=109
good luck!
dcatcha is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
WT trade rear ends.. Bens69PlymouthSatellite Mopar Parts and Cars Wanted 0 05-13-2010 05:07 AM
8 3/4 rear ends 70rrdave B Body Mopar Car Parts for Sale 7 04-21-2010 09:53 PM
66 Belvedere rear bumper. Jason Mopar Parts and Cars Wanted 1 08-31-2009 05:07 PM
Anyone have a rear bumper for 66 Belvedere Jason Mopar Parts and Cars Wanted 0 08-24-2009 07:51 PM
WTB: 65 Belvedere wagon Rear Bumber maralthom Mopar Parts and Cars Wanted 0 07-20-2009 06:58 AM
cadillac suspension kits | range rover suspension
FBBO Sponsors
Roseville Mopar Parts
Dale's Cuda SHop
Charger Specialties
Performance Suspension Technology
Inertia Motorsports
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
