res1vw21
As some of you know I rebuild door hinges for people, recently I have had to change my methods a little due to parts supply but it is for the best because now they are stronger and better then ever before!
Pricing is as follows for any standard mopar: A,B,E,F please email for pricing on C and early A.
$70 a side (top and bottom) or $130 both sides (top and bottom) + $15 shipping for the return ride. $50 core charge will be added if bought outright.
What you get for your money:
* Media blasted clean
* Epoxy primer in your choice of gray or flat black or left bare
* New pins in all hinges
* New brass bushings on both top hinges
* Star wheels removed, repaired and reinstalled
* Springs repaired
* Assembled and and sent back to you labeled for position
The reason they are not greased is so you can paint them to match your car then use a spray lube type grease for long life.
Paypal Preferred, Money order is accepted.
Thanks a bunch
-Ross-
* Springs repaired
Thanks a bunch
-Ross-
