RussDavis
1971 Satellite Sebring Plus Road Runner clone.
Brand new 77-440 cast crank, with KB step dome pistons, completely redone 906 heads, Comp Cams XE284.
Comes with the original N code 383 #’s motor 99,000 miles. Needs rebuild but complete.
1968-4 Speed Trans (23 spline).
New 11” Center Force clutch.
8 ¾ with 489 case 3:23 Sure Grip.
Newer Flow Master exhaust and headers.
New Holley 670 vac sec. electric choke. Needs a 750.
New fuel tank and sending unit, and fuel lines.
All new brakes with new front discs. And rear lines.
Original interior and head liner.
New dash and column harnesses all electrics work, even
factory tach. Body was done (amateur) in 1999 and car
has sat since. Runs very well. Drives and stops good. New tires, new windshield, all correct
RR trim. No frame rot or rust, small floor patches. Clean
title, registered and inspected. Drive her home. 9000.00 FIRM.....
