john.thompson068
This morning I had no spark. Then I used a test ECU and coil and still no spark. I bypassed the MSD ballast resistor. Still no spark. I put the old ECU and coil back on, reconnect the ballast resistor and go to buy a new battery. I come back and still no spark. I bypass the ballast resistor again and no spark. I hook the ballast resistor back up and all of a sudden spark.
I had spark for about five minutes. After the car warmed up to about 180 degrees the ignition starting cutting out and it lost spark. I noticed that the ECU was too hot to touch. I tried bypassing the ballast resistor and no spark.
Is it possible the ballast resistor is bad and is causing these problems? The ballast resistor is the MSD 8214 and is about five years old, but has very few miles on it. Maybe about 1500 or so. Car has MP electronic ignition kit.
A few things lead me to suspect the ballast resistor. One, it was the last thing I disconnected and reconnected before the car suddenly had spark. Two, I wonder if a failing ballast resistor might be overheating the ECU and causing it to quit working until it cools off.
The symptom here seems to be that when the car warms up or has been running about five minutes, it starts running all erratic and then loses spark.
