help 72 ralley dash
bizam123456
9:37 AM
Cleveland,Ohio
I need some help with my gauges. there is 2 connectors on the fuel,temp and oil gauges.each has 1 wire connected but 1 empty connect on all 3 .also there is a pink/red connect,and when connected to fuel gauge it will work perfect.Does any one know if i can splice from pink/red(has power) to temp and oil any help would be great..
This is what was used to distribute the voltage limiter output(+5volts) to the gauges.
If the pink/red wire you mention looks like this, No! it can not be used to power gauges as it is full un-switched 12 volts and will distroy gauges.
Thanks its a pink&red wire with the same end connect as the other gauges. The black wires must be missing do you know were you can buy the at?also there's no voltage limiter on my cluster.
Does it look like this? That's the cigar lighter connector, same circuit as above, full 12 volts. You will need to locate a voltage limiter, there are new electronic versions available if you can't locate an original one. The output lead harness may be more difficult to locate, may need to make up something.
