62/65 B-body heater core
62MAX
9:46 PM
PA
Feedback: +1 / =0 / -0
I have two 62/65 b-body heater cores for sale,both in excellent condition with no damage and "NO" leaks.$50 ea. + shipping
Thanks,
Bill
Dosent the 65 b body have an inlet and outlet.Maybe the one needs to be turned around to see the outlets,if it does i will take the top one .
the 'inlet' actually is the heater control valve. which is separate item
I havent had mine apart,not even sure what it would look like,But i know it has two heater hoses running to it .Am i not understanding something ?
How's this ?
This seems to be different then mine ,thanks for your help
You're heater control valve goes in that inlet then the other hose goes to the control valve.All 62/65 cores are the same.
62,any ideal how tough it is to get a new water Valve
Probably not likely.I have the ones that came with the above cores,they are good if anyone needs one.
If it is an original valve it can be rebuilt. Don't throw away those good cores. I had mine done for around $80.00 including return shipping.
Heater valve rebuilding, Joe Hudacek-715-392-6169:happy7:
control vavle
MrKlinger
Here is a picture.
Jeff
