Another update. The process of narrowing the rear end has begun. The pumpkin mounting face was leveled and a protractor was place on the spring perch. The spring perch was 5* off compared to the pumpkin surface. The 5* angle is rotating the pinion up. Then the spring perches where cut off using a plasma cutter. Then the excess metal ground down flush with the axle housing. Pictures:
I then laid out the spring perch new location and the final cut location. The new spring perches came from US Car Tool. The spring perch was tacked into position 5* tilting the pinion up.
The black line is the final cut point. The opposite side was done in this same manor.
While cutting the old spring perch off, you can see where the u bolt has distorted the axle housing. Picture:
I hope this doesn't cause issues? The opposite side spring perch tacked in place. Picture:
If you look at the center of the axle housing the factory bird **** welds have been repaired. Both top and bottom welds where bevel ground and re welded.
Now we are at the point of no return. My plan was to use the original axle ends. So the 1st cut made was on the axles larger end section. I made the cut here thinking that it was a socket that slipped over the axle housing.......WRONG, and I have cut both ends......This isn't a socket end...Now the re-fabrication will be harder to do, due to the different OD of the axle end and the axle housing. The axle end is 5/16" larger the the axle housing. So now I will need to lay out the axle end with a 5/32" lip around the circumference of the axle end and the axle housing.......oh the joy. What a big pain in the rear end this is going to be. If I do another axle narrowing, the axle housing will get cut. It is easier to fit pipe size to pipe size.
The process of installing the axle end was started, but the wife came home from work and that signals the time to stop and have adult beverages..........Lets see if I can dig a deeper hole....lol. Up dates to come.
