1967 Dodge R/T hardtop FOR SALE
paulcars
New Member
6:35 PM
Irvine, California
Asking price - $38,000
The VIN # starts off with WS23L75, which verifies this to be a real 1967 Dodge Coronet R/T. to my knowledge all of the original body panels are present, including the trunk floor, floor pans and quarter panels. A perfectly straight, unmolested, 100% original body. The car has received one cosmetic repaint in the correct ZZ1 Gold Metallic. The body is super straight. There is a slight discoloration mark on the top of the left front fender.
All of the trim on the car is in fantastic condition. The bumpers and original door handles have been re-chromed. The drivers and passenger side mirrors are perfect. All of the emblems are in perfect condition. The bright work is exceptional, with a near perfect original grille, headlight bezels and tail panel molding. The tinted glass is all factory original glass and in superb condition.
The interior is equally as nice, with a flawless dash pad, instrument cluster, gauges and wood steering wheel. All hardware and trim on the inside of this Coronet are original, including the center console chrome, the factory tachometer, chrome trim, door handles and, window cranks. The original sun visors have been replaced and are flawless. The front seats have had new foam cores installed. The rear seat was recovered with a correct replacement from Legendary Auto Interiors. The center console is has no cracks. The carpet is correct replacement from Legendary Auto Interiors. The upper and lower doors were repainted when the Coronet's body was repainted. In short, this is an exceptional, black vinyl interior.
The front suspension has been rebuilt and aligned. The front brake calipers have recently been rebuilt and new custom pads installed. Gas shocks are present at all four corners and operate properly. The undercarriage of the Coronet is absolutely un-restored and original without a speck of rust or rot anywhere
(with the exception of new rear springs)
In summary, if you are a 66-67 B Body fan, you know how difficult it is to find nice, original and unmolested cars. This is a real deal factory R/T with its original body panels. Although the original engine has been updated the original heads and exhaust manifolds come with the car. A rebuilt 727 Torqueflite also comes with the car. Moreover, because this car is not a high dollar trailer queen and is riding on a dry, rust free undercarriage, you can drive and enjoy the car without concern that you are going to destroy its value.
Engine - a real troque monster!
Mopar 500 cubic inch stroker - built by Superior Automotive in Anaheim California
Vert streetable 527 horsepower @ 5000 rpm - 629 lb ft of torque @ 3500 rpm
(RT's came with 440 Magnum engines - 375 hp/480 lb ft & 10:1 comp)
Eagle H beam rods and crankshaft
J&E - SRP forged aluminum pistons - 10.25 to 1 compression Mopar Performance aluminum heads - ported and bench flowed
Comp Cams hydraulic roller cam and roller rocker arms
Crane roller lifters, Holley 4150 HP 950cfm double pumper carb - reworked by Superior, Mopar HP aluminum intake - stock, Milodon 7 qt. oil pan, Schumacher "Poly-lock" motor mounts, MSD Pro-Billet ignition system, TTI - 2" ceramic coated headers TTI 3" exhaust, X pipe and tailpipes, DynoMax Super Turbo "Hemi" mufflers. (Car comes with original iron cylinder heads, exhaust manifolds and chrome valve covers)
Drivetrain: GM 200R-4 automatic overdrive transmission - .67 OD, 9 1/2" billet torque converter, separate transmission cooler, Wilcap Mopar to GM trans aluminum adapter and high torque starter, custom made driveshaft with HD u-joints. New Mopar Performance XHD rear leaf springs & bushings. Mopar 8 3/4" rear end with new US Gear 3.55 gears and Sure Trak. New Nitro HD rear axles. (Car comes with a freshened 727 Torque-Flite transmission and driveshaft)
Wheels, tires: Wheel Vintiques Magnum 500 - chrome/steel Front: 15 X 7- 4-1/4" backspace - 215/75/15 Coker Classic RedlinesRear: 15 X 8 - 4-1/2" backspace - 235/75/15 Coker Classic Redlines. Factory power brakes - heavy duty front disc and drum rear. Power steering. KYB gas shocks front and rear. Front sway bar. (Car comes with 2- additional 15X7" Magnum 500 wheels)
Interior: No changes made to original guages other than added oil pressure gauge & Sun tach. Has original working AM radio and front/rear fader. Has original 150 mph RT speedometer. Factory tinted glass. Legendary reproduction seat covers & new foam cores. Classic Auto Air - air conditioning system. 3 spoke Deluxe wood grained steering wheel. Console mounted tach (not hooked up) Rear seat speaker.
Exterior: Paint color - ZZ1 - Mopar gold poly (1967 original color) Dual rear view mirrors - optional remote driver mirror. Levant grain vinyl roof covering. Rare optional lower side stripe. Optional rear bumper guards. All body panels are original as is undercoating.
Other: Total Dodge R/T's built in 1967: 9,553
Car is located in Irvine, California (Orange County)
Is the price posted in the ad?
