Bansheestrokeher
Hello i have read many many post from this site and many others over the past year or more trying to gather as much info as possible. I have however just joined this site today and have finally started the process of my motor build which will be going into a 74 SE Charger that I am swapping from an original 318/904 to a 440/727. This will be a street car and ocassional race car. It will be by no means a full blown drag car though
Currently I have a full 440 motor dated 4-3-1975. Here is the combo I am thinking of going with.
*L2355 six pack replacment pistons with moly rings
*Factory LY reconditioned rods with ARP bolts
*OE crankshaft
*Going to have the machine shop mock it up and set the deck height at zero to -.005 down the hole
*452 open chamber heads, stock (no port work)
*MP 509 cam
*Electronic distributor
A couple questions I have for everyone is
#1 what springs are being used with the MP 509? Trying to stay away from duel springs for the fact of a tight budget and they require extra machining work to use.
#2 what size head gasket should I use to help achieve proper compression for pump gas
#3 should I have my decked and if so how much? I measured all my combustion chambers tonight and all seen to range in the 90-95cc (I'm told this is normal for mopar iron heads to vary) which seems pretty large to me?
#4 can anyone tell me roughly what my compression ratio will be with this setup?
#5 is the 509 cam a bit much for a street car? I am seeking a cam that will perform well with this setup but I was however wanting a nice long duration and high lift to give it a nice heavy "broken" idle so to speak
Thanks Sam
*OE crankshaft
*MP 509 cam
Thanks Sam
