JimKueneman
The AC controls. Is it normal for the blower fan and the connector at the back of the vacuum switch (makes the contact for the AC compressor clutch) to get so hot that you can burn your fingers on the pins? I had to rebuild my vacuum switch (the plastic pins were brittle and the back snapped off, drilled and tapped #4 screws to fix it. I also have pulled these two switches apart and cleaned them up and made sure they worked nice a free. I have no other conclusion other than this is normal but man they get hot.... It has discolored the phenolic board where the spade connectors are connected to the board.
Also should the AC compressor be engaged when the heat button is pressed? I can see why it may be to dry out the air for condensation on the glass but just checked to see if that is they way it should work.
Jim
Jim
