96Formula6sp
Got a few things that we no longer need for our car. We have done a manual swap and none of this is of any use to us. Clearing it out as its just going to take up space. Stuff is in Columbia SC. Can ship smaller items. Not wanting to ship big stuff. Everything came off a 1972 Dodge Coronet with a 318 and a 727.
727 Auto. Was running but slipping. Fluid was pretty black. Found no kickdown cable. Pretty much a core. Was rebuilt 3? Lemons races ago. Comes with the torque converter and the flex plate for a 318. Cooler lines were pretty bad so they were trashed. $50obo
318 LA Starter. Should be the 130 tooth count starter. Came off a 72 coronet with a 727. Big boy unit. Worked fine on removal. Always turned the car over. We went to a Dakota 143 tooth. No use to us. $50.
Power Steering box. Nothing wrong with it. Our car came with a new one in the back of the car. Since were were rebuilding the steering column was swapped it out. Fluid was clean and no leaks. Normal play. Not sure on mileage but figure it was the original to the car. Good to use or maybe you want one to rebuild. Missing the high pressure line fitting and the return line section. We needed those for our other box. Remans are sitting around $225+. Asking $150.
