MeanGreen Cordoba
New Member
Hey Everybody New to this Site here looking for a little help in finding out what are my options as far as replacing engine in my Córdoba ...over the summer I did a radiator swap filling the new one up with water just to make sure it wasn't still running hot with intentions of draining and filling with antifreeze before winter ...sure you guys know where this story's going ...well a month or so it got extremely cold here engine froze up pushing freeze plugs out the bottom of engine hoping I hadn't ruined the engine last week I replaced the freeze plugs with expansion plugs and after running for 15 minutes the car still had not run hot when I pulled the dipstick to check oil level is when I discovered that oil and coolant were mixing couple minutes later temperature gauge started to go up...so now I'm looking to replace my engine ..It currently has a 2barrel 360 engine and what were my options and where would be a good place to find a motor ...any suggestions or advice on my situation will be greatly appreciated..thanks in advance
