Kernel Sanders
- 8:21 AM
- Dec 13, 2008
- Ottawa, Ontario, Canada
Has anyone here created their own frame connectors for a 73 or 74 Charger?
Here is what I will be doing to my 74 Charger to help stop the slop but want to go a little further;
- Will be installing solid aluminum K frame bushings I picked up from cudazappa on moparts
- Having a machine shop create a set of steel tortion bar x member bushings from a set of aluminum ones I also picked up from cudazappa.
- picked up an awesome replacement tortion bar x member to replace my bent up one (PO must have snagged it on something in the center)
I'll be bolting and welding in the tortion bar x member with the steel bushings but I also want to weld in frame connectors... the only way I see to do this IS to the torsion bar x member... Is there a better way?
Thank you kindly
PS The only other idea I had was to perhaps eliminate the removable torsion bar x member and using the holes in the transmission x member that are there to allow the torsion bars though, and weld in some torsion bar anchors and finding shorter bars... now keep in mind I have done NO research on this option as I'm not sure how long the bars are from A-bodies which I assume are shorter.
Thank you kindly
