steve from staten island
- 9:06 PM
- Sep 24, 2012
- staten island,ny
Well actually i dont as my wife scan came back good and I'm ok but i need car advise. This F-ing car is beating me up. Long story short is it definitely has a knock in the motor, Ive been around enough to know what i hear is no lifter its a knock and i suspect a rod. It knocks when its hot or cold. Its not bad and you wont hear it with the hood shut but its knocking near #1 cylinder. The engine runs ok and has no blow bye. I went cheap at the time as money was tight. The block is a 383 out of a 1970 and had the cylinder bored 30 over and the crank cut. It had rebuilt TRW rods and new pistons. It was very dirty and when i took it apart the rods were tight on pistons. I soaked them in oil and loosened them up. I put the motor back together. The heads were done by a competent shop. I had the motor run on a test stand and all was well. But then again it was loud. Either way it has the knock.
I have the original block which has never been bored or had the crank cut. I ran it when i first got the car and pressure checked the system with a radiator pressure checker and there were no leaks or blown head gasket
So my thinking is get that short block rebuilt and maybe next winter switch things around. My question is who should i send the motor to. I was thinking of contacting Carolina engine rebuilders sending the everything and telling them build me a stock engine. I really have no idea right now as very soon the car is going to get the top done, windshield installed, side glass adjusted and whatever else
I cant wait anymore to drive this car, its been way to many years and I'm getting to old, so whats anybody's thoughts on what should i do with the motor and thanks for the help
