Wietse
Is the standard filter after the fuel pump??
Bit confused now.
Bit confused now.
Not sure who your asking. If on mine, filters for two carbs, between pump and carbs.Is the standard filter after the fuel pump??
Then why do all automakers have a screen or filter on the pick-up?............................MOWell, i assumed the standard fuel filter will be located before the fuel pump to protect the pump as well.
But now i am in doubt if the fuel filter sits on the suction or discharge line on my car, i am away from home for a few more days so i cannot check it at the moment.
If it is installed on the suction line of the pump it does not matter if the pick-up suction screen in the tank is installed or not because all mechanical components are covered.
Difference between old, and new. Newer ones, all I've seen have those high dollar inline filters, outside the tank, probably with the pump inside the tank.Then why do all automakers have a screen or filter on the pick-up?
With the junk you had in your filter, I suspect if you look 'inside' your tank, you will find more...and the pick-up filter pretty much gone.Once i will replace the pick-up on the tank i will know how my tank will look like inside.
