Hydraulic Lifter Preload Excessive?
Engine, Trans & Driveline
  1. EngineerDoug
    EngineerDoug Well-Known Member
    75
    31
    Oct 5, 2016
    Los Gatos, CA
    Local Time:
    10:53 AM
    All I can say is, "wow, am I learning a lot from this build!". I just mocked up my 906 heads onto the 383 block, with my Summit K6400 cam and lifters, and Comp Cams 911-16 springs installed. As far as I know, the only thing non-stock about this motor are the cam, lifters, & springs. With a 0.020" nominal head gasket, and a spring installed height of 1.850", the lifter preload is a whopping 0.130". My understanding is that this preload needs to be 0.040" to 0.060" for proper operation.
    I used a dial indicator to measure the compression applied to the pushrod & lifter, and am sure the lifter was on the base circle of the cam. With such a mild cam, is this a surprise? I suppose now I have to get some shorter-than stock pushrods?
  2. khryslerkid
    khryslerkid FBBO Gold Member FBBO Gold Member
    My Photo Garage
    7,573
    6257
    Mar 10, 2010
    Hanover, Pennslyvania
    Local Time:
    1:53 PM
    Yes, get a checking rod, watch for the lenth capabilities because there are different ones. I used Smith Brothers for the new pushrods. Fast turnaround, Great product!
  3. charger318
    charger318 Well-Known Member
    My Photo Garage
    134
    13
    Nov 4, 2013
    illinois
    Local Time:
    12:53 PM
    Things like decking the block, shaving the heads, different thickness head gasket, or change on the base circle of a camshaft will all effect the pushrod length needed for the correct preload. What kind of rocker arms? Stamp steel or adjustable? A cam with 488 lift or 588 lift just tells you how much it opens the valve, you could of had a camshaft with a smaller base circle and new cam is larger causing the extreme preload.
  4. lewtot184
    lewtot184 Well-Known Member
    3,342
    1474
    Aug 21, 2011
    indianapolis
    Local Time:
    1:53 PM
    there's no way i would use those springs at 1.85" installed. according to comps catalog that's 140+lbs on the seat, and 300lbs+ over the nose.. that cam is just a generic version of a stock magnum cam that had about 115lbs on the seat and 240lbs over the nose. you can get adjustable push rods from smith bros; just did this a couple of weeks ago.
    • Agree Agree x 2
    • khryslerkid
      My Photo Garage
      7,573
      6257
      Mar 10, 2010
      Local Time:
      1:53 PM
      I found the same thing useing a Sum 6401cam. They recommend the 911spring. They are useing a higher installed height to get their numbers and thats just wrong. Doing the math they were way too strong. I went with a Crane 99839 spring. I'm not sure if that would be the right diameter for your app. I did some machining for the spring seat on my 452 heads. (Check out "My Photo Garage")
    • Badvert65
      Badvert65 Well-Known Member
      My Photo Garage
      625
      245
      Oct 11, 2013
      Brightwood, Virginia
      Local Time:
      1:53 PM
      I placed shims (about .045" in my case) under my rocker shafts to reduce preload. That was about 30 years and a few thousand miles ago (1/4 mile at a time) Haven't had any problems with it.
      • Like Like x 1
      • Agree Agree x 1
      • Garys1969RR
        Garys1969RR Well-Known Member
        1,657
        342
        Apr 12, 2012
        Colorado
        Local Time:
        11:53 AM
        You know Doug, I had the same problem with my 451 build, 509 cam, stock valve train. The plunger was way down in the lifter. I like it to be near the top. So I simply made steel shims from an old .020" steel head gasket, and stacked 2 shims between each pedestal and the rocker arm shaft, with the bolt going thru the center hole of the shim. That brought the plunger to near the top of its travel, very near the retaining clip. That set up ran great at the track for 4 years!. 40 or 50 mid 12 second passes. I think that reduced pre load by .040 on the valve side and .040 on the push rod side, for a total of .080" less pre load. Am I looking at this correctly? There are also rocker shaft shims available thru various sources.
      • Garys1969RR
        1,657
        342
        Apr 12, 2012
        Colorado
        Local Time:
        11:53 AM
        With 080" less total valve train length , that would move your plunger up to .050 pre load. .130 less .080 equals .050". That would be right where you want it.
      • texas69bee
        texas69bee Well-Known Member
        976
        395
        Dec 3, 2013
        texas
        Local Time:
        12:53 PM
        Was the dial indicator over the push rod or over the spring?
      • Garys1969RR
        1,657
        342
        Apr 12, 2012
        Colorado
        Local Time:
        11:53 AM
        Yea that would make a difference. It should be directly over the push rod to accurately measure lifter pre load. My question would be, how do you bring the plunger up to measure how far down it was? Or do you tighten the shaft bolts until there is no preload, then measure how far down it goes when the rocker shaft tightens against the pedestal?
      • khryslerkid
        My Photo Garage
        7,573
        6257
        Mar 10, 2010
        Local Time:
        1:53 PM
        I tried shims once. Changed the geometry of the rocker tip to valve stem travel. The rocker tip started off center and ended up near the edge of the stem.
        You have to use a pushrod checking tool to get the proper lenth measurement and have them made. Or use the adjustable pushrods.
      • miller
        miller Well-Known Member
        1,872
        555
        Jan 5, 2014
        Tom Bean,Texas
        Local Time:
        12:53 PM
        That preload distance is measured from the top surface of the tappet 'cup', to the bottom of the retainer clip. That's the only way I measure it.
        Only reason for the preload, is setting it all for positive contact, push rod to rocker arm, allowing for the 'soft' hydraulics to work through the cycle. Main thing (like a busted record) is keeping the tappet cup off the retainer.
        Methinks I'll leave it at that.
        • Agree Agree x 1
        • lewtot184
          3,342
          1474
          Aug 21, 2011
          indianapolis
          Local Time:
          1:53 PM
          this is what i recommend and have done. the 911's diameter is too big for stock retainers; cranes will work with stock retainers. the 6400 cam should work ok with stock magnum springs.
        • lewtot184
          3,342
          1474
          Aug 21, 2011
          indianapolis
          Local Time:
          1:53 PM
          rocker shaft shimming can be a blessing or a curse. it shouldn't be done without checking the scrub pattern at the valve tip. mopars tappets have a lot of plunger travel, .200+". i've found that .060"-.090" works ok. if you can get by with less thats ok too, but don't let the push rod cup come in contact with the retaining clip.
        • Challenger340
          Challenger340 Well-Known Member
          63
          55
          Mar 4, 2014
          jaffray, B.C. Canada
          Local Time:
          11:53 AM
          You mention installing the 911 Comps at 1.85" ? Probably too much seat & over the nose V/spring pressure for my liking ?
          but,
          what are your actual Valve "tip" Heights as measured from the un-machined V/Spring seats that you have .130" Lifter preload ? and, how much Block/Head Milling was done?
          I see shorter, or adjustable pushrods in your future.
        • lewtot184
          3,342
          1474
          Aug 21, 2011
          indianapolis
          Local Time:
          1:53 PM
          factory stuff always had a lot of preload. probably well over .100".
        • EngineerDoug
          75
          31
          Oct 5, 2016
          Los Gatos, CA
          Local Time:
          10:53 AM
          The issue with the springs has got me concerned - these are the springs the tech line at Summit recommended. Sounds like I need to look into a different spring. I did check the preload at the rocker arm cup (where it contacts the pushrod). These are stamped steel rocker arms. I don't have measurements of the valve tip height, but I don't think any block or head milling has been done. Dead stock.
        • lewtot184
          3,342
          1474
          Aug 21, 2011
          indianapolis
          Local Time:
          1:53 PM
          i don't have a $1000+ Rimac spring tester but my little hobby cheapie tested a 911 at 145lbs@1.90" and 155@1.85". the 911's spring rate is 373lbs per inch according to comp cams.
          • Thanks! Thanks! x 1
          • Garys1969RR
            1,657
            342
            Apr 12, 2012
            Colorado
            Local Time:
            11:53 AM
            Doug, what is your method of measuring the pre load? I don't understand how you are doing it. It would be the distance from the top of the plunger travel, to where it is when the lifter is on the base circle and the valve train is in place. Seems like it would hard to do with stock rocker arms. How do you do that?............. And as far as valve springs are concerned, I wouldn't use any more pressure than the cam manufacturer recommends. You don't want to lose a cam lobe.
          • EngineerDoug
            75
            31
            Oct 5, 2016
            Los Gatos, CA
            Local Time:
            10:53 AM
            Yes, I would estimate the open/closed pressures to be 314/141 lb, respectively - using 1.85" installed height. Looking at the Crane 99839 spring, I compute open/closed pressures to be 307/103 lb. I called Crane to chat with them, and they also recommended this spring. They indicated it would work with stock retainers and no head machining required.
            If I use the Crane springs, do I need to shim them to bring up the closed pressure at all? Is 103 lb high enough?
            Thanks.
