Moving the mountain(s)to mohammed
Bladecutter
"Pursuit of Shape"
6:46 PM
USA
A twin Beech blade..aluminum alloy. Grind to bottom of corrosion in 40 grit. All the dark areas are low spots. Can't fill since it will be natural polish finish, so the highs have to be cut down with longboard & 40, to lows to de-ripple for accurate, undistorted reflection.....moving the mountains.
Gettin there....it's a marathon.
Second pic is what i started with....heavily imbued with corrosion. My Buddy Pete w/ the cutting wheel.
The "pockets" are a muther. Last two days pushing this board....gotta be 6-7 hours real.
Still have to cut into the back
IMG_20170617_133152.jpg IMG_20170617_135033.jpg IMG_20170617_140014.jpg IMG_20170617_140053.jpg
Cut into backside. I have this little jewel to contend with on the leading edge. This blade is easily 50 years old........
Hours later.....getting there
ballin' the jack.....born to block
The one beauty is always having a reflection to work by....road map
Looks nice! Just for curiosity, how many hours do you generally have into one of these projects from start to finish?
Hard to be specific....generally anywhere from 80 - 250 hours.
This on will start picking up in pace now that im almost to the bottom of flaws in 40 grit....i can start sanding north by tomorrow i hope. I'll probably be about 80 hours by 1st polish.
The piece pictured here was 230 hours
A bit more coaxing yet.....short time's always the hardest time.
