NV3500 In B-Body
New Hemi Engine Swap
  1. 66poly318
    66poly318 New Member
    3
    0
    Mar 11, 2016
    denver
    Local Time:
    11:56 PM
    Cool, thanks for the knowledge. I'll be on the hunt for a dakota donor. You gave me all I need to know.
    I'll keep everyone posted on my progress...
  2. drdodge
    drdodge Member
    20
    5
    Sep 1, 2014
    mississippi
    Local Time:
    1:56 AM
    for my 360la and nv3500 project ive decided the pilot shaft does not go up into the crank far enough to use the old style pilot bushing. I will be trying to get the magnum bushing onto the back of my crank or make something..
  3. kb67mopar
    kb67mopar Well-Known Member
    2,907
    860
    Sep 28, 2011
    Luxemburg, Wi
    Local Time:
    1:56 AM
    Thats good to know.
  4. drdodge
    drdodge Member
    20
    5
    Sep 1, 2014
    mississippi
    Local Time:
    1:56 AM
    the magnum pilot bearing looks like it will fit the 360la crank end where the tourgue converter connects up.
    How will you connect or get a speedometer setup on the nv3500??
  5. Phil McGrath
    Phil McGrath Well-Known Member
    128
    48
    Feb 28, 2015
    Silverdale Wa
    Local Time:
    1:56 AM
    Ahhhhh, I though the new hemi's were orange? You know that orange paint is worth another 100hp.......
  6. Tori
    Tori Well-Known Member
    303
    110
    Jun 4, 2017
    Pismo Beach, CA
    Local Time:
    11:56 PM
    kb67, can we get an update on this swap ? How has it been holding up to the 5.7 ? I'm heavily considering this swap behind my 318 and wonder how you like the throw of the shifter ? Did anything ever come of the questionable 1-2 synchro's ?
    Thanks for the write up, it's answered a lot of questions.
  7. kb67mopar
    2,907
    860
    Sep 28, 2011
    Luxemburg, Wi
    Local Time:
    1:56 AM
    So I learned last year that trans I swapped in was just plain wore out. Those synchros and eventually led to a vibration. So Last year I swapped in another with only 36k miles on it. I love the trans in the car. The only thing I should probably adjust is where my slave cylinder bolts to my clutch pedal so that I get a longer throw on the clutch. The trans seems to be holding up fine so far. I guess you could say I killed one already but I honestly feel that was just pure wear.
    I have that one here you could rebuild if you want it, I would give it to a good home.
    • Thanks! Thanks! x 1
    • Tori
      303
      110
      Jun 4, 2017
      Pismo Beach, CA
      Local Time:
      11:56 PM
      Thanks, but probably not worth shipping.
      How would you rate the shifter throw ? Does it seem short enough for a car ? It's been a minute since i've driven a Dakota with a manual, and can't remember how "truck like" the shift was.
    • kb67mopar
      2,907
      860
      Sep 28, 2011
      Luxemburg, Wi
      Local Time:
      1:56 AM
      I can't say it bothers me at all. If that seems to be an issue for you just get a short throw shifter for it. I know someone makes one as I have seen it for sale.
      • Tori
        303
        110
        Jun 4, 2017
        Pismo Beach, CA
        Local Time:
        11:56 PM
        Cool. Now i wonder if the shifter will come thru in the correct spot for my factory console.
