mykers
Hi there, you all have been so helpful and I am thankful for that. I searched for a forum with a similar question but to no avail. So here we go...
I just picked up a 1970 Roadrunner, 383, 727, yadda yadda. It has been sitting for 10 years and I spent two days getting it fired up; everything went fine. Question is the car is overheating so I am going to do all the standard replacements: thermostat, hoses, water pump etc.
I did notice the radiator was empty and had wolly-type boogers on the first row. My question is this I want to do a radiator flush but with the radiator outside the car. I didn't think it would be wise to perform a full flush after I changed the water pump, thermos, etc and possibly push those boogers or sediments back into the engine block. I figured once I feel satisfied with the cleanliness of the radiator, I'll do a full flush. So is there some sort of solution I can leave in the radiator to break the potential sediments or boogers if you will? Or should I just use a good ole hose to power-push-clean the radiator?
Any help would be appreciated. Also, I will eventually get the radiator remanned, just trying to get the car t remain running for longer period of time.
