Do you have worn door hinges? Let me rebuild them for you
res1vw21
5:54 PM
seattle
As some of you know I rebuild door hinges for people, recently I have had to change my methods a little due to parts supply but it is for the best because now they are stronger and better then ever before!
Pricing is as follows for any standard mopar: A,B,E,F please email for pricing on C and early A.
$70 a side (top and bottom) or $130 both sides (top and bottom) + $15 shipping for the return ride. $50 core charge will be added if bought outright.
What you get for your money:
* Media blasted clean
* Epoxy primer in your choice of gray or flat black or left bare
* New pins in all hinges
* New brass bushings on both top hinges
* Star wheels removed, repaired and reinstalled
* Springs repaired
* Assembled and and sent back to you labeled for position
The reason they are not greased is so you can paint them to match your car then use a spray lube type grease for long life.
Paypal Preferred, Money order is accepted.
Thanks a bunch
-Ross-
Here is a set headed out to a customer with a '65-'70 B body!
And a set headed to a customer with a '79 Aspen R/T!
whats turn around time?
Another set of A body ones waiting to be shipped out! (they were just painted hence why the pins and bushings aren't in the uppers yet)
Hinges
Do you buy cores, I have all 4 off a 64 polara. Need your magic, but otherwise ok.
Thanks, bluepainter
Thanks for the offer but I have more cores right now then I can get build any time soon,
I am trying to get a built inventory but it's challenging with all the customer ones I am doing. I would be interested though if the roller wheel isn't worn.
Please Read:
I need to update my add, but due to rising material costs and demand I am now charging $200 + $15 shipping a set. I am also doing them once a month on a weekend (usually the last weekend of the month)
I will still be offering the core exchange program ($75 fully refundable within 3 months) but we need to talk to make sure I have cores in stock for your vehicle.
For the B body people I now offer '71-'74 hinges kinda. The '75+ ones are a direct bolt on and a superior design, but you will need to provide cores as people have bought all mine and not returned the cores.
These are superior hinges folks, I take them all the way apart and fix everything including the detent and redo the uppers, both things that other hinge re-builders don't do. These also come back painted in gray dp50 epoxy primer so they won't rust and can be quickly scuffed and painted body color.
Also for an additional $5 I will include two strips of 3m strip calk that goes around the bolt holes and seals them better then the factory sealer.
Thanks -Ross-
