SOLD A-833 trade for a nice 727
HemiRR
12:34 AM
Ohio
Ok here is the deal. I have an A-833 for a b-body I want to trade for a nice 727. I helped my friend out and let him take my 727 for a trade he had going on. Long story short my car is going to be running much faster than I thought.
If your trans has a reverse pattern valve body in it that would be a plus. I believe the trans is date coded for 69, but I included the numbers on it so you can decode it your self. The synchros will need replaced but everything else inside looks perfect. The trans rotates really nice and the teeth on the gears are really nice. I was going to do a 4 speed swap into my roadrunner but putting the 727 back in will put me on the road faster.
Pics
Where are you at in Ohio? I don't have a ready to drop in 727, but I do have a couple of BB 727 transmissions that I would like to talk to you about. One is from a motorhome with a short tailshaft and drum brake with virtually zero miles on it. The other is a factory tranny from behind a 383...nothing special. Together they could make a pretty stout transmission.
Im in Groveport ohio. I might be interested. You can just PM me the details.
I have several 727's for big block or raised block mopars. Do you have a bellhousing and clutch and brake pedals for a B body or just the 833? I'm in Illinois but have a daughter that lives near Columbus,Ohio.
I only have the transmission, and shifter (no rods, or shift lever). I got the trans to do a 4 speed swap originally. My car had a really nice 727 in it but my friend needed it (my car was not drivable at the time). I now have acquired a 440 for my car and want to drive it, so a 727 will go back in it.
I just want a good condition transmission to go behind my 440.
