FOR SALE ENGINES 383/440/413/ intakes /heads/valve covers,pullys ect,
joel
7:44 AM
edinboro pa
Feedback: 20 / 0 / 0
ENGINES ---BIG BLOCK
1964 413 nice bores, steel crank , shortblock needs one piston, turns over clean, 350.oo
1965--383 cast 6-7-65 block & steel crank 250.oo
1965 383 shortblock,, seized from sitting clean,, 6-16-65 250.oo
1970 383 dated 1-6-70 non h.p. shortblock 350.oo
1970 383 long block dated 10-10 69 H.P. -blockrods&steel crank 450.oo
1971 383 85k miles ,, ran when pulled ,,complete turns over ,2bbl ,non h.p. 350.oo
1971--383 cast 4-19-71 non h.p.block only 250.oo
1971 --383 cast 11-18-71 non h.p. block & steel crank 250.oo
late model 440.short block, steel crank ,
from truck----siezed from sitting 250.oo
76-77 late model 440 ,short block, cast crank
siezed from sitting 150.oo
65 413 block dated 4-2-64 no caps 100.oo
HEADS
906 heads fresh rebuild never ran clean 300.oo pr
516 heads closed chamber,, original may or may not need rebuilt 125.oo pr
346 heads may or may not need rebuilt 75.oo pr
INTAKES
62-67 383 iron intake #2205968 100.oo
67-69 440 intake # 2806178 i have the following dates
5-18-68
10-11-67
100.oo
thermoquad iron intake 20.oo
67-69 440 iron intakes many to choose from 100.oo
66 440 intake # 2206000 100.oo
65 413 intake # 2206000 100.oo
68-9 383 h.p. intake #2806301
70 440 iron intake #2951736--dated8-23-69 125.oo
71 383 iron intake #2951666 100.oo
72 factory dual plane iron intake#3614014 25.oo
VALVE COVERS -BIG BLOCK
69 440-383 h.p. nice 125.oo pr
71 set 50.oo pr
72 set 100.oo-blaseted primed
many more 25.oo pr
no 70s
water pump housings BIG BLOCK
big block water pump housings original iron diff cast #s avail.
67-70 383-hemi water pump housing #2780987--100.oo
big block power steering brackets 75.oo
big block pow st pump with brackets ,.blasted painted, 100.oo
big block 4 groove crank pulley for steel crank 40.oo
air cond pulley and bracket for big block steel crank motor 40.oo
BIG BLOCK non h.p exh. manifolds 50.oo pr many to chosse from
stock rocker shafts 10.oo ea
stock rockers 10.oo-set
stock rocker spacers 10.oo-set
stock bolts and special spacers 10.oo set
located in n.w. penn
edinboro pa 16412
Good evening Joel; looking for parts for my 1970 383 motor distributor,exhaust manifolds,power steering pump with bracket high pressure hose. thanks
were these h.p. parts [exh. manifolds/dist] that you needed
I may have some pumps but no brackets, I don't have the hose, I don't have the 70 h.p. manifolds,
THANKS JOEL might still be interested in the pump whats your asking price?
20.oo for a p.s. pump, which style did you need, thanks, joel
JOEL sorry for the delay what ever will fit on my 383 block in a 1970 roadrunner thanks
I have these 2 style pumps , but I don't have any big block brackets
interested in the 67-70 383-hemi water pump housing #2780987... looking for a late 69 date for my 70 383. Any pictures? Come with the water neck? Thanks!
I don't think I have any more with the small heater hose nec for the 70 cars , but ill check, joel
