"Tagged" Radiator
69 R/T
2:04 AM
San Jose, CA
Can someone please explain the "tagged" radiator? What I'm referring to is an OEM factory stamped Chrysler radiator without the part number stamped (embossed) onto it, which has a stamped tag brazed onto the tank instead. In my case it's P/N 2949054, which is correct for my car....kinda strikes me as odd, but I'm told is 100% factory issue.
Do you have a photo of it that you can post?
Does it look something like this?
Yes, It's exactly like that! Cool, thanks for sharing that.
Well, I don't think its legit. I removed the 055 tag and the number stamped into the top tank that is underneath the 055 tag is a much later radiator, something from the mid '70's. So this could not possibly be a correct radiator for my car. What is extremely strange about all this is, mine is ALSO from a '69 Coronet R/T. I am assuming yours is also, considering your forum name.
I would suggest you remove the top tag to check the number underneath. You can easily put the tag back on, some heat and solder is all it takes. I would be interested to know what the tank number is underneath yours.
