1974 Satellite Rear License Plate
'73bird
8:55 AM
Phoenix, AZ
keeps falling down so it cant be seen. Is there a fix for it? Do I need to buy a repo or one off another car?
What do you mean, "keeps falling down?" It sounds like you just need some new plastic inserts & screws you can buy at any auto parts store for about $5
No it flips down for access to the gas cap and it wont stay up keeps falling down so you cant see the plate
Isn't there a spring or two holding it up ? Will look at my Rr when I get home from the salt mine.
This sounds like a job for the handymans secret weapon; duct tape!
Be sure to use the glossy silver, not the matte Grey, for that show quality shine, and be sure to smooth out the tape when you do it, because nothing says "poor craftsmanship" like lumpy duct tape
Sounds like the spring has failed or is just sprung, so you can remove the spring rod and try to put tension back on it, but its tricky to get the spring rod back in place with tension on it.
Had to work late last nite, will get a pic tonite. Definitely spring, as I recall.
So remove the whole assembly or just the rod? Is there a clip that holds it taunt?
Should be pretty easy to either slip it over the tab, or bend the tab up, position the spring, and bend it back down.
My 72 has 2 springs, 1 on each side. Here are pics.
