Engine Torque Strap
Mike Gaines
6:02 PM
Ahwahnee, (Fresno) California
I have attached a pix of the "standard" torque strap that we have all seen. I have one of these on my motor. My motor still has stock "rubber" motor mounts and even with the torque strap the motor still "flexes" or "torques" up on the drivers side quite a lot when I rev it up.
I need to put in a motor plate or steel motor mounts...but...question is:
Has anyone ever used a similar torque strap BUT from the top of the frame up to the open lug on the drivers side of the water pump. I saw one on an old 63 Plymouth super stocker but I have concerns about the motor flexing enough where it might just break the front off of the water pump...any thoughts...or has anyone one seen anything like I am talking about ?
Mike just go to solid motor mounts. The straps only work so far. My '66 Satellite had a Mancini strap, still had a broken motor mount. I am installing Moroso solid mounts. In the old days in my '65 Coronet I made my own solid mounts that worked great. Don't dick around with the torque strap.
I have been using the torque strap like in your pic above in the standard location along with Mancini's rubber mounts that have been modified with through bolts. I think they are around $50. Kind of double insurance in my mind, without the vibration of a solid mount. I went this route after have a Poly Loc failure. Although my cars are only street driven and only 545 hp. Don't most guys runs solid mounts on cars that are primarily strip driven?
I guess it depends on your torque level if a torque strap like the Mancini deal will work. Mine didn't. Not sure how much the vibration is increased with a solid mount. My experience is only with a drag race application. My street/strip 500" motor broke the motor mount with the Mancini strap. I'm going solid.
Mike, made this one , stock mounts bolted through, a clevis pin mount off of the top frame rail, to the water pump ear, worked great.
We replicated the rubber portion of the drivers side mount out of aluminum. Painted it black and in it went. No failure orvibration on either the 65 BB or my sons 850hp SB turbo car that currently use this method..
Mike I thought you had a motor plate installed. I used steel on the passenger side and on the driver side rubber with a chain bolted to mount and block.
we used to run a spring steel strap from the top of the frame to an empty head bolt hole, worked for 14 yrs. on a hemi superstocker.
Mike, made this one , stock mounts bolted through, a clevis pin mount off of the top frame rail, to the water pump ear, worked great. View attachment 374765
MoPower...this is EXACTLY the setup I was asking about where I had concerns of the torque strap load from the engine torque actually breaking he ear off of the water pump....Please confirm how long you have been running this setup with no problems....it is exactly what I want to do...(in advance of getting a motor plate). Thanks, Mike
Hi Mike, never had any problems, for years same set up motor making close to 825 hp at the flywheel. strap is a 1/2" stainless steel with two hyme joints (fancy turnbuckle.)
street/ strip driven motor don't budge. i would preload the strap slightly since its sitting on the rubber mount
I was never able to feel much of a vibration with my solid mounts in my GTX.
That car was driven on the street a lot!
I would just go with a motor plate if you are worried about the water pump ear.
I ran a turnbuckle on my Duster in the 80's for three years.
It was only a 340 but it was a 4 speed.
That never broke the waterpump.
