1970 super bee 440 manual driveshaft length???
Jimclo2002
4:09 AM
Lewes, Delaware
I need a little help. can someone tell me for a 1970 super bee 440 Six pack, 4 speed manual. what is the correct driveshaft length???
Thank you for the help in advance
jim,patti.driveshaft is 3.25 diameterX44.60 cl to cl of u-joint,patti
1970 Dodge B-body manuell Dana 60 is C/C U-joints 50.96".
We changed the transmission in my sons 1970 Super Bee from 4 speed to automatic, (he kept going thru clutches) and the driveshaft from the 4 speed worked in the auto too. I'm pretty sure it's the same length in 383 or 440 equipped cars.
GARY,PATTI. MY BOOKWORK CALLS F/`70-71 B BOODY AS PT#2883667,3.25 DIA.,44.60,9.75 AXLE. also,pt#2883775, f/`70-`71,3.25 dia,42.60,9.75 axle. hope this helps,patti
Hi Mr Patti
I measured the drive shaft that came with the 1970 super bee I purchased from you it measured 49 7/8
Jim
Hi Mr Patti
Jim
jim,patti. did not have the correct one. can have this one shortened and u r good,thx
I've have a driveshaft from a 68 GTX 4 speed Dana 60 laying around it's 50 1/2" With 7290 u-joints. Just removed it from my car when I changed it back to an 8.75" rear. Any help?
440 with a 4 speed , w/Dana rear
What is the correct length center to center u joints?
Found this on DodgeCharger.comForum
Got this on another dodge Charger website. 1970 Coronet/Super Bee.
oops thought it didn't post
Is that manual or automatic transmission?
Doesn't matter but all 440 six-pack with manuell came with a Dana 60 from factory, all with 9 3/4 Dana are same, the difference between Dana 60 and a 8 3/4 is 1.14".
