Glueing plastic water sheilds.
ddpsnake
2:23 PM
Belleville Canada
What can I use to glue my plastic water shields,I would like to know befor I install the door panels.thanks .
I would "suspect" that you could use body seam filler or liquid nails, but I'm not positive. Plastic can be tough to stick to sometimes. I've always just used duct tape since you can't see it.
You can use 3M trim adhesive (yellow snot), but I prefer PLIOBOND contact cement. It is easy to work with and makes removal of the barrier in the future easy.
PLIOBOND is also excellent for re-gluing door fabric, vinyl, etc. Use it to reset your door card clips, too.
I used 3M spray adhesive for mine - no issues removing them...
Rope caulk hardware stores, doesn't harden and if you want remove plastic no problem.
moparnation74 used it on his restoration.
Well I just got some duck tape,just to stick it on,wile the glue dries.Thanks
MY trade was a flooring installer,still is,part time now lol,contact cement is a no no here ,my brain is fried some what.
Kelly does it have a nasty odor,it says never dries,i would think it stinks.
never noticed any odor. It does not dry hard, which make it easy to remove if needed and to replace it you just press it back in place.
Originally they used 3m strip caulk white with some tape in specific areas. I used 3m black strip caulk just fine with my new plastic barriers.
Here is what my rear barriers looked like.
It's called Mortite.
Make sure the surface is clean of oil, grease and leftover silicon caulk from the previous idiot that owned the car (ask me how I know). I used the Mortite. If you use the spray adhesive check whether the instructions require application to both surfaces.
Ok boys I think its going to be the rope caulk hopeful Home Depot has it,will post a pic in a few day as to how i made out.Thanks again my mopar family. Cheers.Don.
Try a local hardware store. TrueValue or Ace !!! I'm a TrueValue dealer and I stock it.
