BeepBeepRR
I installed a right stuff front brake conversion on the Road Runner. This kit says that if the wheels came on cars that had factory disc brakes then those 14 inch wheels will work. Anyhow The conversion went pretty easy with a couple hiccups. The dust shields need a little trimming around the large bolts that connect the spindle to the lower ball joint. I have not completed the entire setup yet due to having a crushed brake line at the rear passenger side and a clogged rubber line at the rear end. I have since replaced both parts rebuilt the back brakes with new wheel cylinders and shoes. Then while pulling the rear drums off the axle on the adjuster side of the car came out a little. Turns out the adjuster was crushed and not able to re screw into the adjuster plate. Anyhow 400 dollars later we now have some axles in route to the house. Also replaced all front steering parts with Moog parts. Also couldnt stand the chrome valve covers so I bought some off ebay and cleaned up the engine a little. Before and after pics at the bottom.
