73disc spindles
Dreamcatcher
Will fish for food
6:44 AM
Keystone,S.D.
I have a set of 73 disc spindles it is my understanding they will fit my 68 charger. Is this right? I am installing QA1 upper and regular lower control arms. Getting rid of the big drum brakes on the 68. I have the distribution block and booster from the 73.
Just use all the parts for a 73, seals, bearings, calipers etc. You may have to use the lower ball joints. Not sure what year they changed to a bolt on arm for the tie rod.
Yes they'll fit but you need to figure out which side you are going to put them on before you bolt them home.
