nothingelsematters
Joined the forums awhile ago but have been mostly lurking. Got my new garage done and the car moved in, so the time has come to get to work. A little history first, bought the car when I was 15 as a rolling chassis and got a nice 440 out of a junkyard Charger. Had it rebuilt in 2000 with, best as I can remember
9.5 comp
Forged crank and rods
906 heads ported with 2.08 intake 1.74 ex
0.060 bore (one cylinder had to be sleeved)
.484 Mopar purple cam
M-1 Intake
Holley 800 cfm carb
Pulled a 727 out of a junkyard also, can’t remember what it came out of but was built with a manual valve body. 3500 stall converter. 8 ¾ rear with 4.30 gears and 28x10 slicks.
I raced 3 years when I was in the Air Force but after I got out I moved around for work and didn’t have a garage so it sat in the car trailer for the past 12 years. Last time it ran was 2007. Now that my budget is no longer shoestring and I have a nice heated garage to spend my winter in I want to get it track ready.
Lots of work to do and now that I am a little older and wiser (subjective, I know but give it to me!), I want to do it cleaner and better. But I’ve also been out of the game for so long I am looking for some advice.
I would rather not touch the short block if at all possible. I know that I need a new cam/lifter/push rods/ and valve springs at a minimum. I am considering aluminum heads since I already have to buy all of that. I also need a new carb but from what I understand the M-1 single plane is still a decent intake.
Car ran 11.80’s back in the day but I always struggled with a major stumble off the line. Messed around with the cams on the carb but never had much luck getting it to launch consistently. Always had the best luck if I got to the line right around 180 degrees but if it was colder than that I would bring it up to about 2800 rpm on foot break then launch it and it falls on its face and have to peddle the throttle to keep it running then she would take off.
So what I’m looking for is advice on cam/lifters/valve springs. If I’m doing all that should I go aluminum heads? Can I get a higher compression ratio without touching the short block? Solid lifters perhaps? Carb choice? If you were building this for pure track use, what would you put into it?
Edit: updated valve sizes
9.5 comp
M-1 Intake
Holley 800 cfm carb
