chargervert
I was going to sell my 70 Charger R/T V code automatic project car,but as I got the car cleaned up,and repaired the worst areas of the car,which is a California car,I decided that I was going to keep the car,and put it together and drive it. No fancy paint job on this one,I want to make the car mechanically sound,and drive it,and continue to finess the body while I do. The car has the matching numbers 440 Sixpack engine in it,but it needs to be rebuilt,and needs pistons and a crankshaft. The original plan was to build the matching numbers engine with a Source 440 stroker kit,and Source stealth heads. The current plan,though is going to use the fresh built 68 440 that I have for my other 70 Charger R/T project,an 18 spline 4 speed,and a 3.54 Dana 60 that is also slated for that project. The plan is to rebuild the front suspension,and brakes,change out the rear axle,and drop in the 68 440 with a sixpack and drive the car,and break in the driveline that will be going into the other 70 R/t when the car is ready for it. Today,I went out to the garage and dug out the Dana 60,all the new suspension,and brake rebuild parts for the project.
