FOUND wheel hub
that i don't know but ill look tomorrow
Thanks very much, I'm new to the mopar stuff so learning about there parts and what you can and can't buy for them. Haven't had a mopar for about 40 yrs (yikes HA) so am way out of touch with them. Thank you
A 66 coronet front drum is the hub/drum assembly.
I have one, but shipping to Colorado would hardly seem worthwhile.
I have several with or without the drum. Just over the hill from you.
The drum is being made as shown in Rock Auto but no one makes the hub.
Thanks, where are you located? I need one without the drum as I have new drums. Someone before me changed the studs and must not have supported the hub and bent it?????? I thought it was a warped drum but was the hub. Let me know Thanks, Dennis
ou should order an oil seal and possibly bearings as well.
Be careful ordering bearings from RockAuto - they will probably be Chinese junk. Get some Timken bearings.
I made that mistake already....and the good bearings ended up costing the same amount.
Don't know if these will open but here they are. About 6" wide and 1 7/8 from the flat area to the outside. Thank you
