- 8:39 PM
- Feb 20, 2012
- Maskachusetts
My dad bought me a pair of these 40+ years ago & I later bought anther set myself. If they've lasted 4 decades, they must be good.
Have a set of these in 6 ton rating. My Belvedere sat on them for nearly 20 years and without failureI use Torin. I think I got them at Northern Tool. Forged and double lock.
https://www.amazon.com/Torin-Big-St...coding=UTF8&psc=1&refRID=K30PSFB1C2ZEJEGB69QT
I am looking to replace the pair of 3 ton Pittsburgh jack stands I bought last month from Harbor Freight. I'm totally uncomfortable with them supporting my car. The load bar shifts side to side when I push down on it (when they are ratcheted, extended). One of the bases doesn't rest flush on all four corners. It teeters a little diagonally. I've just come to the conclusion that they are cheap junk.
I think I'm going to order a pair of the US JACK 3-ton D-41609. I like the double lock mechanism that engages two teeth on the load bar, instead of just one. Larger base 10" x 10". Contact area at the top of the load bar is wider and longer.
I found a post on some other forum where a guy was questioning the welding work on a pair of his US JACK 6-ton units. But that is the only negative comment I've heard about US JACK.
I like this guy's review about US JACK stands:
"I purchased these stands for my son because I wanted to be sure he was safe under a vehicle. His safety was of utmost importance to me and the extra cost was trivial. It is my belief that you spend good money on good things when it comes to protecting things that matter to you. End of story."
Seems like Officer Higgins, who posted about these stands, agrees with the above review.
yep i agree used them quite a bit, they engage very firmly. The old ones you could get to release by just barely lifting the weight off the jack. These however engage more deeply. I have looked them over, are they the best who knows but better construction methods then the old cheap ones, and they are made here in the usa, and i like that.I am looking to replace the pair of 3 ton Pittsburgh jack stands I bought last month from Harbor Freight. I'm totally uncomfortable with them supporting my car. The load bar shifts side to side when I push down on it (when they are ratcheted, extended). One of the bases doesn't rest flush on all four corners. It teeters a little diagonally. I've just come to the conclusion that they are cheap junk.
Yeah, can't beat using a good block of wood. I do question just how did this guy get the truck into that position for those 2x4s?You can save a lot of money by just using old lumber you might have lying around the garage; you will note how safety conscious this guy is by chocking the rear tire. Wonder if he is welding up the rusted fuel line! Ahh...he has little concern about dying of old age!
A box crib or cribbing is a temporary wooden structure used to support heavy objects during construction, relocation, vehicle extrication and urban search and rescue. It is commonly used to secure overturned motor vehicles, and debris within collapsed buildings. From WikipediaExcuse my ignorance. Cribbing/ cribbage? You hold your cars up with a card game/ board game? There must be another definition i couldn't find.
Currently, US Jacks is backordered for two weeks for the 3-Ton Stands (D-41609).
A benefit of the Harbor Freight recall
Yes I did. They were under the front frame rails of my Super Bee for 3 months.. From Feb 15th to May 17th. Along with a Harbor Freight Daytona 3 ton floor jack under the K-Frame for extra support. This combination held the car in place with no movement for 3 months continuously without a problem.Did you end up ordering the US JACK 3-ton D-41609?
