Runner71
Okay so you probably seen the latest upload on his advance...
I got mine set at manifold vac so i can run high inital timing and get alot off vac with
232/245 for better idle stability and throttle response and the car moves pretty good + helps with burn at idle and light cruise.
or should i try ported with 0 vac @ idle.. have i not fully understand this?
Ive read a couple off old threads about this but can someone just simply it all? Im i overthinking this?!
First ever big block build and tune, think it's sounds pretty healthy?!
