19 69 GTX
- 7:31 AM
- Apr 30, 2016
How do you adjust end play correct..I know how to turn but but will it back itself off
You don't need a dial gauge.. you could simply use a piece of metal clamped in place and feeler gauges to set the end play.
The factory put in the nice tapered roller bearings. Way better than any ball bearing will be there. Adjusting is easy.
Doubt you have a spool with the stock bearings, but look down the axle tube with a light and tell us what you see in the center.
