64 Belvedere Throttle Cable Info
MCODECUDA
8:22 PM
Sherrills Ford, NC
I have a 440 with a Holley Street Dominator and I need to get a new throttle cable. I see them in standard length and some that are 1” or 2”longer. What is everyone using and who did you get yours from?
try Brewers or A&A trans or Joe Suchy
I have the +1” with a 426W and a CH4B. Fits well. The original would simply not work. My best guess is this would work and the +2” shouldn’t be required. Got mine from Mancini.
I like the Lokar,cut to fit is a wonderfull thing.
881777-e6087a4a7b5b68bdeece845f807c9cb0.jpg 14138111_1091144424296506_8789297796398539824_o.jpg 33044198_1705139959563613_2624492508419194880_o.jpg
I ended up ordering one from Mancini’s that was 1” over stock and it should fit perfectly. I can also use all original Mopar throttle brackets even with the 1” taller Holley Street Dominator intake by adding a cruise control bracket to the existing bracket and putting the throttle cable in where the cruise cable would normally go.
D33441AB-914D-4835-8CFC-C583DA99711B.jpeg 368DD89B-77A7-4146-9AF0-00EE555D7F59.jpeg
