1969 satellite 4 door
Long4door
11:35 AM
Tacoma wa
Hello , Tacoma wa. First mopar very excited to get started with a pretty clean satellite may be actually 75k on the car looking at zero wear on foot pedals and such anyhow snow has delayed my trailer, hoping for your help as I get started!
welcome to the site,it looks really clean. :thumbsup:
Welcome, Fresh paint ? Looks great,I'm a fan of more door Mopes.
Welcome from Alabama, it must be nice to find one almost done. The best I ever find is ones with little to no rust, but that to is a big plus.
Little rust is where I'm at... scared to fire it up its basically abandoned going to take any precautions. Disconnect fuel change oil order plugs and wires if not more.. any threads you can suggest would be appreciated, 318
One of the best features (and under-used!) is the SEARCH box in the upper right
of the page. This joint has an unbelievable amount of research material built up
over the years!
Yes, don't run it off the gas in the tank if it has sat for more than a year. Make sure your fluid levels are full. Make sure the points have no corrosion. You can run a emory board through them to clean. If it was known to run, I would wait on things like plugs, wires, filters etc. With a hot battery, disconnect the coil wire and crank engine over enough to see oil pressure. Then do the same to check for spark. If both are good then add a little gas to the carburetor and see if it fires. By this time if the fuel pump is good you should be able to keep it running. I never change oil until the engine has been brought to operating temperature at least once. Then tune as needed, plugs, points, wires, filters, etc. There may be threads on this but most was just common mechanical knowledge when I was coming up. Dig in and try as this car looks to have been well cared for over time and probably doesn't need much.
Thank you that's great
