joemopar
Good afternoon. Hello everyone. I need some help with a few problems with my car. My transmission is leaking from the linkage cable.. My Tech says, there may be excessive play in the transmission shaft. He replaced the O-ring but it did not help. He was wondering if you can sham it or something.?
Also, when I change the oil and filter, Mopar I've done it twice since I had it , I warm it up and put oil in the new filter first .it takes a long time, around 5 minutes to get oil pressure .when starting. First, I pull off the coil wire. Then first spinning over the engine. spinning over the engine off and on four different times. Then I start it with the coil wire on , no oil pressure yet I shut off that again a few times then the oil light goes off and the oil pressure is almost 80 lb. When idling. I have aftermarket gauges in the car. The oil pressure is 35 40 when the car is hot. Help! How do I fix this? Thanks in advance.. Joe.
