junebug
Has anyone used a Edelbrock RPM Intake on a 383 with a Holley Carb while using their Stock Road Runner hood? If so, What type breather and what clearance did you have? Thank's.
Is that a drop base and a 3" filter? Thank's for the help.Not sure if it is the same manifold, but I'm running a performer RPM with an Edelbrock 1411 carb with no problems. Never did measure the clearance though.
Thank you.I use a 1.25" drop base with that setup. I think I have a 5/16" carb gasket as well. Around 7/8 - an inch of clearance if I remember correctly.
Yes, I believe it is a drop base. It is a 3" filter pictured, but I changed it to a 2" now (no picture of it though).Is that a drop base and a 3" filter? Thank's for the help.
