It's always something
jusglazin
10:13 PM
Charlotte, nc
Just bought a new transmission for my 66 belvedere. Go to swap it in and the damn mount location is different. Didnt bother to check that B vs B/E tailshafts are different. Get ready to bolt it up and the mounting pad is almost a foot to far forward.
Geez time to get out the welder...
If the output shaft length is the same, just swap output housings. It's easy.
Geez time to get out the welder...View attachment 1290228 View attachment 1290229
Looks more like 2 1/2" to 3" to me. I wonder if an automatic crossmember will do the trick.
What I was thinking also.
This almost new trans crossmember I bought from Brewer's allows installation of '70-up transmissions into older
b-bodies (like my '68 GTX).
I swapped 4 speeds shortly after I used this one, went from a 23 to an 18 spline from '68 and used the
old crossmember, so this one is shiny and gathering dust on the shelf now.
Do you need it @jusglazin ??
I think my setup is the same as yours. I was able to use my automatic crossmember during my 4 speed swap by installing it flipped the opposite way.
Or, "with the help of an a-dapter kit" as Johnny Cash once said . . . fabrication time?
You have the wrong crossmember. Get the right one and it bolts together. Post 3 & 4 show the right one.
If the difference in your pic is what you are calling a foot (12"), you need a new tape measure too... :poke:
Ha ha, you guys are so correct. Thats why I come here! I forgot I cut the last one which was for a Auto to make it work. Need to look in my scrap parts to see if I still have that piece to weld back on. Otherwise I hit one of you up for the correct crossmember.
