1971-74 B-Body Rocker Drainage
Bob Nossal
Dodgefor72
10:00 AM
Milford, MI
Is there drainage in the rocker panel in front of the rear wheelhouse for 1971-74 B-Body models? I don’t see anything underneath.
I was assembling the quarter window and thought it would be a good idea clean out that tight space.
There is an opening way underneath the rocker/quarter, and IIRC it is
a smaller rectangular slot, it also could have rounded ends, and be very
close to the rocker pinch weld seam. If I had the 72 Charger quarter panels
here with me, and not in storage, I could tell you promptly. Good luck.
Thank you.
Here is the drain that is in the seam between the quarter and the rocker. There 3 or 4 drains along the bottom of the rockers.
