Holley Sniper EFI and Tachometer
64Orange
5:33 AM
Newport Beach, CA
Good afternoon FBBO!
For anyone using a Holley Sniper EFI set up, how did you set up your tachometer?
I am not sure what kind of wiring or set up I need.
Thank you!
factory tach? I had to use a MSD Tach Adapter to get the correct reading. But I used the Holley Sniper with the Holley Hyper Spark setup. Depends on what you are using for ignition. Most factory setups use a grey wire from the tach to the negative post on the coil. The Hyperspark is a little different so I had to use the tach adapter to make the factory tach work correctly.
I don't have a tach yet. I see they have a Holley EFi tach but it doesn't look anywhere close era correct.
Let me check on the setup. I think I also have the hyperspark set up
Dark Brown wire off the 10 pin connector. It was the only wire off that connector I used. I'm using an Autometer.
I'll have to check and see but the brown wire seems to be what I used for the tach signal. Its in the supplemental harness which is also for electric fans and what not. I have to download the manuals real quick.
I am using a Sniper EFI hyperspark system: distributor, ignition, and ignition coil. I was wondering if I could use a Sun tach or Stewart Warner tach. I'll have to dig deeper about that brown wire. And what kind of Autometer are you using? I know they have a few in their line up that looks vintage
That's great! Which wire are you using and where does it come from?
The brown wire from the 10-way plug - blue and green are used on the ignition on the same plug....nothing else used on mine.
A bit untidy for now...undergoing a small re-wire in the coming weeks.
