1 Wild R/T
So I'm doing what I need to do..... It'll be back in one piece tomorrow....
LA I'm changing some things around on the Red vert... Replacing the RV2 with a Sanden & replacing the stock alternator with a 120 A Denso off a Landcruiser...That has to be for a LA or Magnum engine.....The Big Block water pump non A/C pulley is already breathing on the WP mounting bolts. More offset would be worse.
Actually I did that on the mill... It's good to have options....It worked out well for me...
It's always nice to see when guys think around a problem and come up with a solution instead of a pages-long internet exercise in 'futility by committee' because there isn't a quick-and-easy 'kit' fix.When I was doing this stuff twenty five, thirty years ago it was because nobody made parts to do what we wanted.... Now you can buy a kit for that... But the kit often takes the easiest route, not really the best route.... For those who chose easy the kits are nice... I prefer thinking through the project & doing it the best I can...
Gotta admit, I didn't expect to have to section a pulley... I figured something was gonna fit...Nope...
To be honest I wonder if some of their brackets are drawn from Google Earth photo dimensions. Quite a bit of spacing is required on the small block intake for the support bracket on the Sanden. And I had to shave one of the other brackets to fit due to tight clearance.I've done a Sanden in place of the RV2 on a small block before using the Bouchilion brackets & to be blunt, they suck....
Have you thought about running a snake belt system? They even soak up less hp.....Belt alignment is pretty good, won't finalize the P/S till I take the car apart... I have spare beg block pullies & brackets but no small black power steering pump stuff...
Looks like the stock parts are going to locate the pump about .40 to far forward... Gonna have to make a new rear mounting bracket...
View attachment 1559430View attachment 1559431View attachment 1559432View attachment 1559433
I already have V belt pullies... I had to modify the alternator pulley but I didn't have to make or buy it... The A/C compressor also was a V belt design real Sanden (not a Chinese knockoff) & I got it years ago NIB for cheap... So no, not gonna bother with a serpentine system... Honestly Serpentine systems look to modern on old cars IMO... It's bad enough using a non-OE Alternator & Compressor but I care about reliable more than OE...Have you thought about running a snake belt system? They even soak up less hp.....
